Re: Johnson 9.9 1976-1980
I will try to be a bit clearer:
The 1980 9.9 has 2 wire coming out. When the motor is running, if a check voltage I get a reading of 36-44 volts. That motor has low compression on lower cylinder. I will try to fix that later this summer.
I've picked up a 1976 9.9 that does not have any wire coming, this one runs great.
I'm using the new motor on a sailboat but my marina does not offer shore power. I have to take the battery out of the boat and bring it home to recharge. Battery placement and securing device make that operation a pain.
My question was really what is the difference between the 2 engines. What is required to move from one motor to the other if of course it can be done.
