Re: 10% Ethanol gas with yamaha
my suggestion is to do a search through this forum for some of RODBOLT's answers to the use of E-10 fuel i think you will find that the answer works out to be "NO"!!
Here is an extract i have copied and pasted from yamaha's website:-
Fuels
ETHANOL BLENDED FUELS
OUTBOARDS
Q. Are Yamaha outboards motors, 4 stroke and 2 stroke, designed to operate on Ethanol Blended Fuels.
No, All current and previous models are NOT designed for Ethanol Blended Fuels at any percentage. (ie. E5, 5% and E10, 10%).
If Ethanol Blended Fuels are used you may experience driveability and running problems, fuel component deterioration and damage due to moisture.
PERSONAL WATERCRAFT (PWC's)
Q. Are Yamaha PWC's 4 stroke and 2 stroke, designed to operate on Ethanol Blended Fuels.
Year Models prior to 2000 are NOT designed to operate on Ethanol Blended Fuels. Year Models 2000 and after are desogned to operate on Ethanol Blends at a maximum of 10% (E10)
1. Will my early model Yamaha outboard run okay on standard unleaded petrol (91 ~ 93 ron)?
Yes! All Yamaha models, from the early 1970's have been designed to operate on lead free petrol in the octane range of standard unleaded.(91-93 ron).
2. Will I cause any damage to my outboard if premium unleaded or high-energy fuels are used?
No. However, if you encounter any running problems as a result of using such fuels, change back to standard unleaded (91-93 ron).
3. Fuel Notes
With any fuel, ensure you obtain it from a reliable source, and that the fuel used is always fresh. Stale fuel can damage an engine.
Hope this helps you with your answers
