Hello everyone first time poster and here is my problem with a 1989 150 gt on a 89 basscat sabre.Out of the water it appears fine but when put in water it will max out at around 1200 rpm.So far i have replaced spark plugs 0.30 gap new timing base,tried a remote fuel tank to eliminate inboard tank problems and replaced all fuel lines.Spark jumped a 7/16" gap but not sure how much of a snap it should be.Did a compression test and cylinders were starting with top one 105/103/90/100/100/100.Carbs were cleaned and fuel pump rebuilt by a friend as i am a little nervous about playing with the carbs as you can do more damage than good if you have not done it before.I am a little skeptical of the work he did but he does a lot of small engine work as he used to be in the trade.I have not had it working since i got it,previous owner stated it started to only take off when it wanted to and then it would just go at trolling speeds.After the last time out i noticed something that may mean something to knowledgable members of this board.When it was in the water under load tilt and trim did not work and i would have to pull back on the throttle to get it to work.
Thanks in advance Jim
Waiting to fish a little further than the boat launch but it is good on GAS!
