I'm having an electrical problem.
Description of the boat: 1975 Starcraft Capri 20' fiberglass I/O 888 mercruiser pretty much all original.
To start at the beginning: 2 years ago everything except the trim guage, the volt guage and the horn worked fine. The trim guage is intermittently working. last year pretty much the same except fuel guage is off. This year prepped it to go out and everything is reading incorrectly. Tach is off by about 2 grand. Figured it was a ground problem so I ran a new ground from the engine block all the way to the back of the guages. The only thing that was fixed by that was the horn. Unplugged every connector on the thing and reconnected but it didn't help. with key on pulled and twisted on the wires everywhere with no luck. Running in the water volt guage makes it to 13 volts after throttle is opened up. It starts fine batt is fully charged. Also the speedo only shows I'm hitting about 27 MPH which is way slower than the 40 MPH I ran last year. Has anyone had this problem before? Where should I look next?
