Re: Has Mercury Changed Impeller Materials
I don't know for sure if they've changed the material or not, but I know it's fairly standard practice to change it every 2 years if it needs it or not. I personally run a water pressure gauge and even though I only average 40 hrs a year (bass boat) I change my impeller every spring because of a situation that I witnessed with my friends Merc. (story below). Well that AND the fact that it's cheap insurance to not overheat and ruin the powerhead. Parts are cheap and if you do it yourself it takes very little time.
Here's that story: He put a new impeller in, only used it btwn 1 and 2 hours that spring, then he shipped out overseas (military). When he came back 2 and 1/2 years later he took the boat out of the garage, and it needed a new impeller - he had no tell-tale stream at all! Sitting in the same position for extended period of time killed it.
