  #1
Old July 17th, 2008, 03:41 PM
marcb2001 marcb2001 is offline
Default Yamaha 9.9F Not Idling
I have a 9.9 HP four stroke outboard on the back of my 27' sailboat. I am trying to get it to idle for more than 10 seconds. When I start it, the engine revs up faster and faster by itself and then dies. When I start it and cover the air intake on the carb with one hand I can keep it going semi normally for a short period of time. Should I open up the carb and try to clean out the fuel intake jets (I don't have the manual). Or is this a tough job to try on my own?
Marc
  #2
Old July 17th, 2008, 03:59 PM
matt2002's Avatar
matt2002 matt2002 is offline
Default Re: Yamaha 9.9F Not Idling
Make sure the choke is off.
  #3
Old July 17th, 2008, 04:33 PM
its an electric start with no choke. covering the air intake is in sense choking it
  #4
Old July 17th, 2008, 08:01 PM
Yamajoe's Avatar
Yamajoe Yamajoe is offline
Check your fuel lines from tank to fuel pump for restrictions and air leaks, ensure your tank air vent is open, the primer is firm and filter is clean; go to carb, on top of the carb, opposite the electrothermal (choke) valve you will see the air mixture (pilot) screw ensure that this is set at 3 turns out from lightly seated.
If this does not improve matters then a carb. overhaul is in order and while you are at it test the choke valve. the carb work is pretty straightforward but you should get a manual trust me it will pay for itself many times over.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 40hp 1989 not idling... timing? SiLiconD17 Yamaha & Suzuki Outboards 11 October 6th, 2007 09:30 PM
the sweet sound of a yamaha idling .... deejaycee_2000 Non-Repair Outboard Discussions 4 June 21st, 2007 02:34 AM
225 Yamaha idling hot parrothead001 Yamaha & Suzuki Outboards 4 July 25th, 2005 08:09 PM
Yamaha Engine Stalls While Idling sarnajo Yamaha & Suzuki Outboards 3 July 15th, 2003 05:50 PM
Yamaha 200 overheats when idling ssamaniego@msn.com Yamaha & Suzuki Outboards 2 July 19th, 2002 12:44 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
