Hello.
I followed the advice of a professional on this board.
He told me to buy stainless steel truss headed phillips bolts #10-24 and half an inch long.Washers and nylon backed nuts.a 3/16 inch drill bit and 5200.
He claims you can literally replace every rivet in a boat using these.
The 5200 only to be used under the bolt head and the excess to be wiped away instantly.
I did as he said and the results are great.The trussheads look much like rivets and they are a lot easier and cheaper to get than vibration resistant closed rivets.
Hope this helps.
