Please Help,
I have a 2000 Johnson V4 outboard motor. Motor has a problem with starting and cutting off, it doesn't matter if it is hot or cold. Motor starts then cuts off , I have to choke the motor several times then work the throttle back and forth to get the motor to run. Already checked carbs, spark, and compression. Spark jumps 7/16 to1/2 inch in open air, compression tested hot and cold, left cold checked 118 psi top & bottom, right cold 120 psi top & bottom, hot 150 psi right & left side. Ran motor in yard on flush kit motor runs fine. Put in the lake it will not start correctly. It seems that the motor is not picking up the fuel. Here is the model number J90PLSIF Please help
