  #1
Old July 17th, 2008, 12:34 AM
neller neller is offline
Default 65 hp mercury outboard won't start (1969)
I don't seem to have power to my starter. I did yesterday, put a new fuel pump in (electric), then when I went to start it, I just get a clicking noise from the engine. I had the battery load tested, the battery is fine. I tried to jump across the starter and no spark, no turn, no nothing. Starter Solenoid bad? The clicking noise semms to come from the "electrical" block in front of the engine. Any ideas? It does have the thunderbolt ignition.
Thanks,
Pat
Last edited by neller : July 17th, 2008 at 12:42 AM. Reason: edit title, add information
  #2
Old July 17th, 2008, 09:25 AM
JB's Avatar
JB JB is offline
Default Re: 65 hp mercury outboard won't start (1969)
"Outboard won't start" in Engine FAQs.
Let us know what you find.
__________________
RED SKY at night. . .
JB
  #3
Old July 17th, 2008, 01:41 PM
I searched through the forums last night and found a few similar threads with a similar problem, but no solution. It seems that many people disappear after they fix their boat and you don't know what fixed the problem.
Basically, when I turn the ignition switch I get a click or double click. No turn on the starter. Battery is fully charged and load tested. Will have to check the starter solenoid next?
Thanks,
Pat
  #4
Old July 17th, 2008, 01:51 PM
1976SRV190's Avatar
1976SRV190 1976SRV190 is offline
Thanks,
Pat
SOunds simpler than that to me, try reconnecting the battery cables, and attempt to fire it up again.
__________________
"De Oppresso Liber"
1976 Sea Ray SRV 190, 188HP 888 AND 888 OUTDIRVE.
  #5
Old July 18th, 2008, 02:38 AM
I jumped from the battery to the starter and the motor turns. Pulled apart my merc controller and the wires on the ignition are corroded. How would I test my Kill switch while I have it apart and rewiring it?
Pat
  #6
Old July 18th, 2008, 09:00 AM
JB's Avatar
JB JB is offline
Do "Outboard won't start". That will tell you what is wrong.
__________________
JB
  #7
Old July 18th, 2008, 09:01 AM
jetwhine jetwhine is offline
Try moving your throttle in and out of neutral while turning the key. Maybe you have a bad neutral position. I know on my boat I have had problems with this issue. It will click but not turn the engine over. If I move the throttle just a little it will work. Maybe this will help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1971' Merc. 65 hp 650, won't start. allchevy Mercury & Mariner Outboards 5 July 6th, 2009 02:48 PM
1978 Merc 650 with 65 Hp WONT START JesseNKim Mercury & Mariner Outboards 4 April 1st, 2008 12:19 AM
dt 65 seems to hydraulic on start up deejaycee_2000 Yamaha & Suzuki Outboards 0 June 26th, 2006 02:32 AM
65 HP Merc-ran well, now won't start blueskies401 Mercury & Mariner Outboards 1 July 29th, 2002 06:08 AM
'65 MERC900 Won't Start gw-west Mercury & Mariner Outboards 2 April 24th, 2002 03:17 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
