Recently while motor sailing our Mercury 9.9 went from cruising speed to the rpms reving up and the prop spinning without any force to push the boat. I checked to make sure the transmission still engages in the lower unit... and it does. I thought it was due to a shear pin, and I pulled the prop but I can't locate a shear pin in the prop assembly. Does this motor utilize a shear pin?
