  #1
Old July 16th, 2008, 03:09 PM
WhalerGuy WhalerGuy is offline
Default 1978 Evinrude 35 Power Problem
I have a 1978 Evinrude 35 hp on the back of my 13ft Whaler which has been giving me problems since I first bought it. When I bought the boat the engine had not been run in about two years so I replaced the plugs and lower unit oil. It ran fine the first few times I took it out and then it started running rough because the gasket that goes around the mixture needle on the carb had fallen apart. So I made a temporary fix that lasted the rest of the season and worked. In the winter I rebuilt the carb. The first time I took it out after I rebuilt the carb it ran fine, but the next time another problem occurred. The engine would run perfectly fine while at idle and at lower rpms, but as soon as I would bring the throttle up to put it on a plane it would start to run rough. It would start increasing in rpm like it should but then bog down and it would do this repeatedly in short bursts so it would never get on a plane. If I pulled the choke out half way though, the engine would get up onto a plane and run almost how it should except that it would not get to its maximum power at full throttle but really close. So I figured that the whole problem was due to lack of fuel and thought that the fuel pump had maybe gone bad. I then rebuilt the fuel pump and thought that would solve the problem but it didn't. The only thing that I can think of is that the carb rebuild kit came with a new float and float stop which I replaced and that maybe the float is not set right, although I adjusted it according to the instructions and old float setup. I also put a fuel filter on my fuel line which is new but I don't think that is causing the problem even though I know that these engines can be sensitive to air leaks in their fuel lines. If anyone can help me solve this problem that would be great. Thanks, Jeff.
  #2
Old July 16th, 2008, 03:32 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1978 Evinrude 35 Power Problem
you have a clogged high speed jet in the carb. it is in the bottom of the float bowl behind the bowl drain plug. fuel is not getting thru the jet. pulling the choke out, increased the fuel in the cylinders.
http://forums.iboats.com/showthread.php?t=244013
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old May 21st, 2009, 01:36 AM
I know this thread is old, but I still have not fixed this problem yet as other things got in the way last summer. My plan is to hopefully try to get this problem fixed this week so I have a couple more questions. To get to the high speed jet do I have to take the float bowl drain screw out? What is the best way to clean this jet? Also, if anyone has a clear picture or diagram showing the jet itself and how it fits that would be great if you could post it. Thanks in advance, Jeff.
  #4
Old May 21st, 2009, 11:17 PM
Basically what was happening last year was the engine was surging and dropping off repeatedly at about 2/3 throttle which in turn prevented the boat from getting on a plane. However, if I pulled out the choke about halfway it would run much better but not 100%.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1978 35 HP Starting problem donzi427 Johnson & Evinrude Outboards 1 October 3rd, 2007 04:38 PM
35 hp Evinrude 1978 dies while trolling dczoro Johnson & Evinrude Outboards 10 June 18th, 2007 09:18 PM
1978 Evinrude 35 hp long shaft won't run right johnny whaler Johnson & Evinrude Outboards 3 September 5th, 2006 08:48 AM
1978 evinrude 35 hp moehead Johnson & Evinrude Outboards 2 September 7th, 2004 09:19 PM
1978 Evinrude 35 HP won't run sa48burns Johnson & Evinrude Outboards 2 October 1st, 2002 04:52 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
