  #1
Old May 25th, 2003, 10:34 PM
troubledinottawa troubledinottawa is offline
Default 50 hp mercury thunderbolt shifter problems
.I just removed my lower unit to intsall a new impeller kit, well i re-installed my lower unit, it works great excpet that when when i shift on the shifter to forward it goes in reverse and when i shift into reverse it goes into forward?? Which i though was kind of impossible to do? also when in reverse motor lifts out of water reverse lock not stopping motor from lifting? any ideas??
  #2
Old May 26th, 2003, 07:46 AM
Ken G Ken G is offline
Default Re: 50 hp mercury thunderbolt shifter problems
If it shifted correctly before you took it apart then you have your lower unit out of sync with the power head. If your motor is similar to my '77 Merc 50hp then shift the motor into forward and pull the lower unit again. Near the front of the lower unit is a small splined shaft which is your lower shift shaft. There should be a hard plastic or aluminum reverse lock cam on this shaft. This cam is in the wrong position also. Rotate the lower shift shaft until the L/U is also in Forward. If my memory serves me correctly you can not turn the prop counter clockwise while in forward but it will spin clockwise. Now the reverse lock cam took me awhile to figure out and I don't have the motor in front of me so I can't remember which way is faces but I'll explain what it does. The cam engages a rod on the upper half which activates the reverse locks. If you push on this rod you can figure which direction engages/disengages the locks. You have to put the lock cam on the shift shaft in the correct position so when the shaft turns while shifting it will engage the upper rod activating/unactivating the reverse locks. It took me a couple of attempts while reinstalling the L/U but I finally got it right. I know this all sounds confusing but its the best I can do without my motor in front of me. I'm getting the boat out today so I'll look at it again. I can't tell you which way the cam faces without pulling my L/U again but I can probably do that if you can't figure yours out. If you have any more questions post here or email me at kglattha@choice.net
  #3
Old May 26th, 2003, 11:34 AM
JB's Avatar
JB JB is offline
Howdy, Ottowa.Your question, double posted in the Outboard Engines Forum where it belongs, is still active there.Good luck.
__________________
RED SKY at night. . .
JB
  #4
Old September 13th, 2008, 02:50 AM
rustee rustee is offline
does any one know if a mercury quicksilver commander 2000 shifter will work on my 1971 thunderbolt 50 hp.?
  #5
Old September 13th, 2008, 01:07 PM
DJ DJ is offline
rustee,
You're hijacking this thread with your own question. Not to mention, it's in the wrong area.
Open your own thread in Merc/Mariner questions.
Closed Thread
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mercury Throttle & Shifter Problems radartk Mercury & Mariner Outboards 3 June 23rd, 2008 02:45 AM
1989 9.9 mercury shifter problems ohmybad Mercury & Mariner Outboards 2 August 14th, 2006 03:16 PM
mercury thunderbolt 80 hp problems iaincwil Boat Restoration and Building 0 June 24th, 2006 09:35 PM
mercury thunderbolt 50 hp running problems paul bishop Mercury & Mariner Outboards 0 May 27th, 2003 02:50 AM
Mercury Quicksilver Shifter Problems Bryan Mercury & Mariner Outboards 5 July 10th, 2001 11:07 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
