First off, I have a 17 ft key west with a 90 hp yamaha on it. The boat is a 1990, but the motor was put on in 2003. I have an Optima Blue top that is probably about 3-4 years old. I will look when I get home but recently I have been having a problem keeping it charged. I first had this problem b/c I hooked everything directly to my battery,(motor, bildge, fish finder, and 4 speaker+head unit sterio). And as anyone would expect. The battery ran dead between uses (sometimes a couple weeks). Then I installed a battery switch with only the bildge drawing constant power. But it may be the battery getting old or wiring problem/ corosion from salt. But recently I went to take it out a couple days after it had been run and the battery bearly trimed the motor up and down and it wouldnt turn over. I then put the charger on it with the battery switch off and got pretty close to a full charge, or so the meter on the charger looked. with the charger still connected i turned the switch on and the charger went right to full charge. Then i turned the switch off and it went back to charging. Why is this? I have always wondered if my outboard has a alternator on it to charge the battery when running. I assume it would be small if it even did. But I am going to take a look when I get home about the wiring and go get the battery tested also. But My worry is getting out fishing while anchored with the motor off and the fish finder on and sterio going, and my battery dieing. When I was out last after my charging as I mentioned earlier, it started but wasnt a powerful start. I felt the battery wasnt charged when the charger said it was.
sorry for the long confusing post. any susgestions. I dont know how long those optima's are suppose to last but for what I spent on it. I thought it would last longer.
Will Vallotton
Will Vallotton
