Re: Mercury 90 HP charging
For testing, normally open circuit would be 12 - 20 volts idling, up to as much as 100 at full tilt. Rectifier holds it down to 16 - 20, and a regulator can let it freewheel.
If it ohm's out right, it's OK. You don't need to test voltage.
Rectifier you can easily test with an ohmmeter. Regulator, if it doesn't put out is bad.
hope it helps
John
