  #1
Old July 15th, 2008, 11:37 PM
river_rat1971 river_rat1971 is offline
Default 1979 6hp Evinrude Power Loss in Gear & w/ Cover On
I have been checking out several similar posts and it seems I have two problems that could be almost anything, but maybe together they mean something.
First, the motor wants to stall when I put the cover on. Really quickly (10 seconds) it will really lose power. Not a problem if I take off. Nothing pinching. Think I might have an exhaust problem, possibly leaking gasket. I can't tell which one. Tried soapy water without much luck.
Second, it loses rpms in gear. Revs high in a bucket in N, but punks out in gear.
Checked both plugs with a tester and both seemed fine. Compression check showed 42 in one and almost 40 in the other consistently. Seemed low but the threads say that the proximity to each other is most important.
The carb on this model doesn't really have much to adjust.
Again, I know much of this has been covered many times in many posts but I have seen a variety answers that would cause me to rebuild the whole motor. I haven't seen anyone report on both of these problems. Thanks in advance.
  #2
Old July 16th, 2008, 08:14 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1979 6hp Evinrude Power Loss in Gear & w/ Cover On
1st you have an exhaust leak, from the lower unit, to the power head, it does not like breathing exhaust, that the oxygen, has been burnt. it has to have oxygen for combustion.
i would check the compression with another tester, remove the plugs, and pull it thru 6 times each cylinder. 40 is extremely low. have you cleaned and rebuilt your carb?
you have adjustable low speed jet, and a fixed high speed jet behind the drain screw of the bowl. http://forums.iboats.com/showthread.php?t=244013
after cleaning, follow these directions. (Carburetor Adjustment - Single S/S Adjustable Needle Valve)
(J. Reeves)
Initial setting is: Slow speed = seat gently, then open 1-1/2 turns.
Start engine and set the rpms to where it just stays running. In segments of 1/8 turns, start to turn the S/S needle valve in. Wait a few seconds for the engine to respond. As you turn the valve in, the rpms will increase. Lower the rpms again to where the engine will just stay running.
Eventually you'll hit the point where the engine wants to die out or it will spit back (sounds like a mild backfire). At that point, back out the valve 1/4 turn. Within that 1/4 turn, you'll find the smoothest slow speed setting.
Note: As a final double check setting of the slow speed valve(s), if the engine has more than one carburetor, do not attempt to gradually adjust all of the valves/carburetors at the same time. Do one at a time until you hit the above response (die out or spit back), then go on to the next valve/carburetor. It may be necessary to back out "all" of the slow speed adjustable needle valves 1/8 turn before doing this final adjustment due to the fact that one of the valves might be initially set ever so slightly lean.
When you have finished the above adjustment, you will have no reason to move them again unless the carburetor fouls/gums up from sitting, in which case you would be required to remove, clean, and rebuild the carburetor anyway.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1979 200HP EVINRUDE POWER LOSS imported_steven Mercury & Mariner Outboards 1 June 25th, 2006 03:45 PM
1979 Evinrude 70 surge in power/loss of power huntingjustinlouise Johnson & Evinrude Outboards 6 April 8th, 2006 05:36 PM
Power Gain and loss 6hp Evinrude stombs2003 Johnson & Evinrude Outboards 1 May 29th, 2005 09:29 PM
EVINRUDE 6HP POWER LOSS BASSMASTERJ Johnson & Evinrude Outboards 4 August 6th, 2003 11:19 AM
6HP Evinrude loss of power work4bait Johnson & Evinrude Outboards 1 August 27th, 2002 10:45 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
