  #1
Old July 15th, 2008, 12:28 PM
pete500 pete500 is offline
Post 1967 mercury 500 lower unit
hi i have a 1967 mercury 500 50hp 4cyl sn 2118510 im wanting to change the impeller ive tried taking off the lower unit i took off 3 nuts and tried to pry it out but im getting nowhere please help thanks
  #2
Old July 15th, 2008, 12:55 PM
elark7 elark7 is offline
Wink Re: 1967 mercury 500 lower unit
First never pry, it is too easy to crack that case. You have 2 nuts not yet removed. There is a nut on the front top side, I guess you have it off, two on either side in the middle that cannot be removed fully until the lower unit drops partially, two on the bottom side just forward of the prop, and one hidden bolt underneath the aluminum trim tab. Keep the one front topside on a few turns and remove the two on the sides as far as you can, remove the hidden bolt, and loosen the two on the bottom side. You should see the lower unit start to drop. An extra set of hands or a floor jack help at this point. If not lightly rap , don't get carried away, the casing with a rubber mallet along the edge. If you only get a small seperation and the lower uniot still hangs up use a piece of thin tapered wood, like one for shiming a door, to coax the lower unit apart. I picked up a motor that spent its whole life with the lower unit submerged in water while attached to a boat at the owners private lake and I had to use several shims to get the lower unit to drop. Have patience and you will prevail.
  #3
Old July 15th, 2008, 06:29 PM
Chinewalker's Avatar
Chinewalker Chinewalker is offline
Default Re: 1967 mercury 500 lower unit
Sort of... Elark is correct that you don't have them all removed, but the location is a bit off. The 500 doesn't have a bolt/stud in front. It does have one more in the rear that involves removing the trim tab (from the top with an allen wrench) and then removing the nut underneath. So the tally is four nuts to remove, plus the one allen bolt to gain access...
- Scott
__________________
Share A Project Page for 1971 GW Invader Banchie 13
http://www.shareaproject.com/pages/p...,p,433,00.html
Share A Project Page for 1976 American 18
http://www.shareaproject.com/pages/p...,p,404,00.html
Share A Project Page for 1974 American 15
http://www.shareaproject.com/pages/p...,p,405,00.html
  #4
Old July 15th, 2008, 10:02 PM
thanks guys i cant believe how easy that was the tips of the impeller were bent and one was almost gone thank you
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1967 Mercury 650 Lower Unit reinstall ssand746 Mercury & Mariner Outboards 3 June 23rd, 2008 12:56 AM
mercury 500 powerhead to 600 lower unit galvic Mercury & Mariner Outboards 1 February 22nd, 2008 09:00 AM
Lower Unit mercury 1967 950SS dutchweel Mercury & Mariner Outboards 4 May 10th, 2007 03:13 AM
1967 Mercury lower unit gmarshall43 Mercury & Mariner Outboards 5 May 4th, 2005 01:00 PM
1971 MERCURY 500 (50HP) Lower Unit aff Mercury & Mariner Outboards 3 September 26th, 2002 04:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
