  #1
Old July 14th, 2008, 10:18 PM
chkm8's Avatar
chkm8 chkm8 is offline
Default starting problem 2 stroke Mercury 115 outboard
I have a 2 stroke Mercury 115hp outboard which I fill with a 50/1 mix. The engine since I bought the boat about 1mth back has always been difficult to start. It appears to turn over ok but does not seem to get enough fuel. If you give it some throttle and use the choke then by the 3rd turn or so it usually floods. Yes I know this contradicts the not enough fuel theory but there seems to be a fine line between the 2. The bulb for priming the engine will only go hard on squeezing it several times if there is at least quarter of a tank of fuel any less than that and it never fully hardens on priming. Not sure if this is relevant but the engine is also easier to start if the tank is over quarter full. The tank is filled via a cap on the floor at the drivers seat and for whatever reason the boat seems to list to the starboard side. After spending almost an hr trying to start the boat today in an effort to get home we finally tried the desperate measure of using the ropes used to tie the boat to the jetty to physically pull the boat into a more level position and this was the first time it really made an attempt to start. After just 3 or 4 attempts we had it running but I am at a loss as to how to correct the problem. I wont always have help to correct the list or passengers to sit at the opposite side to have a similar effect. Any help greatly appreciated.
  #2
Old July 15th, 2008, 03:26 PM
Chris1956 Chris1956 is offline
Default Re: starting problem 2 stroke Mercury 115 outboard
I would not think the side to side list would have any effect on the motor's starting ability. Those motors (Depending on year) have always been hard to start when cold. The newer ones had enrichener valves rather than choke plates. This was an improvement.
The correct method it to pump the bulb hard, then squeeze a bit more to slightly flood the motor, and raise the cold start lever. Close and hold the choke plates, and crank her for all she is worth.
If the bulb doesn't get firm when you have less than 1/4 tank, you have a leak in the fuel pickup tube in the tank, or a bad primer bulb.
  #3
Old July 15th, 2008, 06:17 PM
chkm8's Avatar
Thanks for the reply.
The engine while always hard to start had on this occasion just been used for a 8 mile run and the attempted restart was only 45min to an hr after we stopped at the jetty. I will try the method you mentioned and also replace the bulb. Though you can tell it is flushing petrol to the engine when priming but for some reason never really hardens and pretty much just feels similar to when you initially try to prime it.
John.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Starting problem 40HP Mercury 2 stroke Zahnimal Mercury & Mariner Outboards 2 October 5th, 2009 01:57 AM
Mercury four stroke 8hp starting problem jrod15 Mercury & Mariner Outboards 1 July 22nd, 2007 08:32 PM
1997 2 stroke Mercury outboard stalls on starting PortageLakesMary Mercury & Mariner Outboards 5 July 21st, 2006 12:36 PM
1999 115 HPEvinrude FICHTS Kleen Outboard Starting Problem... holgo123 Johnson & Evinrude Outboards 1 June 24th, 2006 07:18 AM
Mercury inline six 115 Hp Starting Problem sweetfish Mercury & Mariner Outboards 5 March 31st, 2005 08:04 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
