Re: 1994 225 Mariner Power Loss
When you had carbs rebuilt did they or you setup the TPI sensor? It sounds like its out of adjustment or bad. If its bad it will bog and run super rich on top end.Also check the temp sensor, if it is bad engine timing will not advance above 3000 rpm. This will cause bogging and dieing as you have all fuel and no timing. If you or buddy has DDT you can check these real quick.
__________________
When in doubt,Trim it out!!!
Business Owner & Certifed Technician
20ft Javlin w/250 Junkrude
17ft Bullet w/200 Merc
13ft Allison w/150 I-6
17ft Hydra-Sport 175GT
15ft Allison w/75 Stinger(project)
