Easydoesit
- May 27, 2008
- 5
I purchased a carb kit and manual for this motor, I have installed the kit per Manual it now runs great but only for a minute then quits if We squeeze the Bulb it will start again but only runs about a minute.
I have replaced the bulb and line making sure the arrow on the bulb points to the motor no difference.
Could I have done something wrong on the carb rebuild? Or is there somthing else I should check.
Thanks for any help you can give.
Easy.
Easy.
