I have an 89 baja sunsport 186 with Merc. 4.3L and Alpha One. I have one battery and the original 55amp alt which was recently rebuilt for me. I want to add a 2nd battery to run the radio off of and have a Solenoid swith. My question is, the solenoid I have been told to buy which I did has 4 connections on it. One for positive to each battery and then a ground and another hot wire which only turns on when I turn the key on. I need a suggestion or two where to mount the wire that goes hot when I turn the key. And maybe even the ground. I am going to mount the solenoid in the hatch and have the 2nd battery right behind the original. Oh and any kind of battery suggestions would be great as well. Thanks!
