  #1
Old July 13th, 2008, 02:44 PM
mxtaylor mxtaylor is offline
Default 1970? 25hp Evinrude - no water from exhaust
Yesterday I bought this little motor. It had just been tuned and runs perfectly. I installed it on my boat, and conntected the throttle control cable. I ran the motor in a bucket (proper water level) several times as I was installing it and it worked fine, spilling lots of water with the exhaust. A few minutes ago I ran it in the bucket again, putting it in gear long enough to test the remote throttle lever. It spun up to high throttle fine. But when I started it again I noticed there was no water with the exhaust all of a sudden. I filled the bucket up to the top again to be sure, started her one more time, still no water. I never ran the motor in the bucket for more than 30 secs to one minute. Am I being paranoid? I am worried that I screwed something up by having it in gear in the bucket to test the throttle (again, only about 20 or 30 seconds). I have had trouble with motors in the past and I don't want to overheat this one. Again, last night - plenty of water with the exhaust. This morning - only a little white smoke as exhaust. The engine otherwise runs fine.
Should I be worried? Did I mess up my water pump?
  #2
Old July 13th, 2008, 03:05 PM
woody66912 woody66912 is offline
Default Re: 1970? 25hp Evinrude - no water from exhaust
if you blew all the water out of tank and sucked air at wot very good chance you smoked the pump pull L/U check pump it just remeber it's better it happend there than going wide *** open with no overheat alarm.
  #3
Old July 13th, 2008, 03:10 PM
Quote:
Man that is what I was afraid of. It only ran for a few seconds. I have very little experience at this and I hate to pull the lower unit of a perfectly running motor I bought yesterday.
If I pull the lower unit, how will I know if the pump is bad?
  #4
Old July 13th, 2008, 03:21 PM
chunks will be missing or hub of pump will be spun or pump will be melted to housing or pump will have taken what we call a set. blades will be bent if this is the case pull blades backwards check for cracks .
  #5
Old July 13th, 2008, 04:15 PM
jbjennings's Avatar
jbjennings jbjennings is offline
the blades of your pump should stand out nice and straight like he said. If anything else is wrong it should be obvious in the pump. Don't feel too bad about having to pull it. Most folks replace an impeller on a new-to-them motor just to be safe anyway. It's also a procedure you definitely won't regret learning. There's all kinds of old threads that will show you how to do it. Don't lose the impeller key--it's tiny! Your water level should be about 3 or 4 inches below the exhaust for the pump to work. Using a bucket is a BAD idea. I always use a big trash can (a 55 gallon drum now). If any of your impeller blades are missing, you need to look for them and account for all of them or they may be in the water tube or water jackets inside the power head which could block a passage and overheat your motor.
Good luck,
JBJ
  #6
Old July 13th, 2008, 04:37 PM
Thanks. I did some reading on it and will give it a shot after I get the specific manual for my motor (was reading an old Johnson manual for a 60s 40 horse I have). Are parts readily available for these old motors? Will it be easy for me to find a new impeller?
  #7
Old July 13th, 2008, 04:40 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
that motor is not old, it is just broke in good. parts are available.
here http://www.iboats.com/mall/partfinde...****=866419066
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #8
Old July 14th, 2008, 07:22 PM
I should have said that I was running it in a 33 gallon trash can (as opposed to a "bucket"). And only had the throttle up for maybe 5 seconds, and only running at all for maybe 30 seconds. I will pull the lower unit tonight and see what is going on.
  #9
Old July 26th, 2008, 03:05 PM
Default Re: 1971 25hp Evinrude - no water from exhaust
I bought a water pump repair kit from the local NAPA, and pulled the lower unit. I am not sure if there was anything wrong with the impeller, it was intact, but the grommet between the water pump housing and the water pipe was pretty badly damaged and could have been blocking the flow. I replaced the impeller and grommet anyway and put her back together. The water pump is definitely working now, but, I suddenly the powerhead won't start.
Grrrr. I am startting to feel like I may not be meant for boating.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1970 Evinrude 25hp just purchased!! I have problems... dono16 Johnson & Evinrude Outboards 22 January 7th, 2008 01:01 PM
25hp slows down after 5 minutes - water pours from exhaust? febod Johnson & Evinrude Outboards 16 August 28th, 2006 11:22 PM
"1970" 25hp evinrude wont start. charlesshaner Johnson & Evinrude Outboards 6 September 15th, 2005 01:00 AM
1970 25hp Evinrude carb issue.. salty yank Johnson & Evinrude Outboards 1 March 19th, 2005 04:57 AM
1970 Evinrude Sportster 25Hp fxpthl Johnson & Evinrude Outboards 1 May 13th, 2001 12:47 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
