Yamaha 9.9 cooling Water Problem
I have a 2004 Yamaha 9.9 outboard (long shaft for sailboat). I winterized it November 2007. When I went to start it this season, it started right up, but the cooling water "indicator" stream did not emit emit water. I shut the engine down (30-45 seconds), cleaned the intake screen (no visible dirt), and tired again, obtaining the same result.
Any Ideas? What is the next procedure? I am guess that there may be silt clogging somewhere. How should I proceed? This engine has only 60 hrs on it. No other problem to date.
