  #1
Old July 12th, 2008, 09:38 PM
jaybirdbadger jaybirdbadger is offline
Default 72 evinrude lower unit leak
I have a 72 evinrude 18 hp motor that just started to leak oil from the lower unit. The problem is that the oil is coming from 2 small "holes" on either side of the check screw. What are these "holes", and what can I do to stop the leak? Any info would be greatly appreciated, this motor is running to good for me to screw it up.
  #2
Old July 13th, 2008, 09:45 AM
larky's Avatar
larky larky is offline
Default Re: 72 evinrude lower unit leak
I have no experience with your motor, but it sounds like you are describing the lower unit drain holes. they are there to completely drain the leg of water so that it won't freeze in the winter time and crack the lower unit housing. now, the leg is also the exhuast, so you are probably seeing some un-burnt fuel/oil coming out of those drain holes. hopefully some one with more first hand experience with your outboard will be along soon.
  #3
Old July 13th, 2008, 10:17 AM
Vic.S's Avatar
Vic.S Vic.S is offline
If this oil is black and gungy it is as Larky says just partly bunt oil from the fuel and is normal.
If however this is clean gear oil it is coming from the gearcase, and water will almost certainly be leaking in. I can't picture where these two holes are exactly but I would suspect the drive shaft seals or possibly the O ring seal on the shift rod.
If it is gear oil and there are signs of water ingress (the oil going milky) you should have the unit vacuum and pressure tested to pinpoint the leakage. Or simply replace all the seals, propshaft seals as well. Renew the pump impeller at the same time.
__________________
If it aint broke dont fix it!
If all else fails read the manual
  #4
Old July 13th, 2008, 10:40 AM
Vic.S's Avatar
See also : http://forums.iboats.com/showthread.php?t=207285 in the Engine FAQs
__________________
  #5
Old July 13th, 2008, 01:33 PM
Larky and Vic.S thanks so much for the reply. One more question. The oil is somewhat milky looking. Am I at risk of ruining something if I use the motor for short trips (15 min run time every couple of weeks) until fall when work schedule would allow me to take it apart and replace all the seals? Thanks again.
  #6
Old July 13th, 2008, 01:48 PM
Vic.S's Avatar
Why not change the oil and see how it goes, but fit new seals to the level and drain plugs. I would not worry too much if you are running in fresh water, but would not want to leave it too long in salt water. You can always change the oil periodically if necessary though.
__________________
  #7
Old July 13th, 2008, 02:06 PM
Vic.S thanks again for your input. I have already changed the oil, it looked fine but I plan on doing it often anyway. I really appreciate your help. I will be looking for a manual for my motor so I can start to prepare for what I'm sure will be a pretty tough challenge for me. Thanks again. Jaybird
  #8
Old July 13th, 2008, 02:59 PM
wilde1j wilde1j is offline
If the gear oil was not milky and there was no sign of water, it's not necessary to "change it often". Once a year, in the fall, will do just fine.
__________________
Jim
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
72 johny 100hp hydro-elec lower unit leak jaybo34 Johnson & Evinrude Outboards 6 December 10th, 2003 11:48 AM
72, 50hp Evinrude Lower Unit Replacement sray Johnson & Evinrude Outboards 3 August 2nd, 2003 07:54 AM
Schematic for lower unit '72 Evinrude Donnis Reese Johnson & Evinrude Outboards 2 June 7th, 2002 04:34 PM
72 Mercury 50 lower unit leak Jimbotron Mercury & Mariner Outboards 2 May 23rd, 2002 08:28 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
