  #1
Old July 12th, 2008, 06:54 PM
reynold460 reynold460 is offline
Default mariner water leak
hi guys i have a 84to86 mariner 115hp outboard and when its running i have water coming out around the number 3 spark plug does anyone know what could be causing this thanks in advance for the help
  #2
Old July 12th, 2008, 07:14 PM
emckelvy emckelvy is offline
Default Re: mariner water leak
That's not a cyl head at the back of the block, but merely a cover. At the top of each cylinder is a flat machined spot that the cover seals against, where the spark plug screws in.
The cover gasket is leaking and water's spilling onto the spark plug.
Remove the 1/4-20 bolts holding the cover in place and install a new cover gasket. Pick up a gasket scraper at your local auto parts store or a good razor-blade-type paint scraper from Wal-Mart (cheap and what I use).
Mercury part Number 27-98185-3 or Sierra Marine # 18-2807 (think NAPA).
Here's a link to a picture of the gasket:
http://www.mercruiserparts.com/images%5Cmer%5C830.jpg
Note, if you've run this motor in salt water or alkali lakes etc, you may have a lot of deposits around the bolts. If they require more than normal hand-tool force to extract, STOP and get a propane or MAPP gas torch from Lowes or Home Depot, etc, then heat up the area around the bolt to free up. You don't wanna break any bolts! Then you'll be drilling them out and installing Heli-Coils!!!
You'll need to pull some of the cowling supporting structure off the motor to gain access. The same caveat applies as to heating bolts to get them out.
If you do have stuck bolts, smear on the threads a thing coating of waterproof boat trailer bearing grease and they'll never get stuck again.
It's actually a very easy job if all the bolts come out without a fight. Gasket is not very expensive, either, under $10.
HTH & Happy Wrenching.........ed
  #3
Old July 12th, 2008, 08:54 PM
thanks for the info that will help me out alot i was afraid that i had a cracked cylinder or something
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Mariner 25HP Oil Leak! filfyfisher Mercury & Mariner Outboards 4 March 6th, 2004 04:01 AM
95 mariner 150 efi water leak ugalboogala Mercury & Mariner Outboards 1 November 5th, 2003 06:58 PM
mariner tilt and trim pump leak delprof Mercury & Mariner Outboards 1 July 21st, 2003 08:29 AM
Fuel Leak in 125 Mariner Cowling WANNABE Mercury & Mariner Outboards 1 June 27th, 2002 01:53 PM
1987 90 inline 6 Cyl. Mariner water leak jbrandes Mercury & Mariner Outboards 1 April 16th, 2001 05:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
