  #1
Old July 12th, 2008, 04:18 PM
bmk88 bmk88 is offline
Default 1971 evinrude selectric acting funny
i have a 1971 100hp evinrude with selectric lower unit. it shifts fine but when under full throttle and turning real sharp it kicks back to neutral until i straighten out and idle it down a bit, then its fine again. What could cause this? thanks mike
  #2
Old July 12th, 2008, 04:21 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: 1971 evinrude selectric acting funny
check you oil level, when was it last changed, remember only Type C Premium Blender oil in lower unit. also could be clutch dog going.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 12th, 2008, 04:30 PM
i just changed the oil with type c from my local dealer and it is full. You say the clutch dog? is there a way to test it? thanks mike
  #4
Old July 12th, 2008, 05:37 PM
F_R F_R is offline
If the trouble you are describing is the only time it acts up, it doesn't sound like any kind of motor trouble. Call it cavitation, ventilation, blow-out, or whatever you choose, but it is getting an air bubble around the propeller under extreme manouvers. You can live with it or spend big time and bucks trying to prevent it, or quit hot-rodding it.
  #5
Old July 12th, 2008, 08:31 PM
this motor is on a 1965 16' glasspar. At full throttle it only goes 25-28 mph. the lower unit will stay in forward if im doing 20mph or under. we use it for tubing and fun stuff. if i cant take a hard corner at 25 mph without the lower unit shifting to neutral there is a problem. I dont believe it is cativation because the motor rpm revs high when it shifts to neutral. I wish i had a manual lower unit. mike
  #6
Old July 12th, 2008, 08:40 PM
larky's Avatar
larky larky is offline
I think F_R hit the nail on the head. Its either cavitation, or a slipping prop hub (though I doubt it by what you describe). two things to try. 1. move the tilt pin in one hole. 2. drop the the outboard mounting bracket down on the transom more (that is, if it has been lifted).
  #7
Old July 12th, 2008, 08:47 PM
R.Johnson R.Johnson is offline
That engine defaults to forward gear, it cannot come out of forward except by hydraulic force to the clutch dog. Low oil, or no oil will damage the internal parts, but it will not make it shift out of forward. You have to activate the solinoid by electric signal, to change the valveing in the hydraulic pump to shift that engine to neautral, or reverse.
  #8
Old July 12th, 2008, 09:05 PM
F_R F_R is offline
Exactly. It is always in forward unless you make it come out of forward by pushing the button. OR, if the clutch dog is worn it can pop in and out of gear just like a manual one. However, because of how they are constructed, it is extremely rare to find a worn forward clutch dog in a Hydro-Electric. Anyhoo, worn clutch dogs jump at any time when under load, not just in a turn. And they immediatly slam back into gear with a bang, not wait for you to slow down.
I will admit you could have a spun prop hub, but doubt it so much that I didn't mention it.
  #9
Old July 12th, 2008, 09:38 PM
how could i tell if the prop hub has spun? any other ideas?
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1971 evinrude 125 Selectric Wiring rustytoy Johnson & Evinrude Outboards 2 August 29th, 2008 03:27 AM
1971 50 HP Evinrude Selectric Shift. w2much Johnson & Evinrude Outboards 5 January 8th, 2006 02:43 PM
1971 Evinrude Selectric impeller replacement fishn_n_tx Johnson & Evinrude Outboards 6 April 1st, 2004 07:34 PM
Starter acting funny Merc90HPnewbie Mercury & Mariner Outboards 2 September 2nd, 2003 12:34 PM
1971 Evinrude 50HP (Selectric shift) steveng7 Johnson & Evinrude Outboards 4 March 22nd, 2003 04:35 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
