Bonafishark
- Jun 15, 2008
- 11
I am having issues with the engine cutting out, like someone pulling the kill switch, and have narrowed it down to the high pressure fuel pump in the VST.
Turn the key, hear the HP pump come one, engine starts fine.
Turn the key, dont hear the HP pump come on, engine wont start.
Is very intermittent. Sometimes will run fine all day, sometimes cut out, wait, start up, cut out, run fine, cut out, wait...Have cleaned/replaced all of fuel system parts as per regular maintenance and after reading numerous posts about ethanol problems.
I am wondering if anyone has had any similar issues and what I can do next.
I have checked for loose wires, grounds, etc but have not found any.
Possibly the resistor or a relay switch?
Any help is truly appreciated as I have already been quoted a price of around $800 by mechanic who not only did not listen to the symptoms I was having, but also never even checked the engine itself. He just rambled on about the ethanol problem, how everyone is having them and it's going to cost x amount of dollars.
Thanks
Rob
Thanks
Rob
