  #1
Old July 11th, 2008, 10:19 PM
pubnicobob pubnicobob is offline
Unhappy 1980 Mercury 80 HP 4 cylinder hesitation...
Motor in great shape...rebuilt 15 years ago, used little and babied when it was. Never any trouble until this summer. Starts good, idles good, top end is normal...but usually after motoring along for a period of time at <2000 RPM, when you try to plane off, there is a hesitation at around 2200 RPM. Sometimes the motor seems to recover and speeds up normally...and other times it just seems to pause at 2200 RPM and will stall if not throttled back. Seems to only happen after the motor has warmed up. Fuel filter was just cleaned. Any quick things I can check before it has to go to the shop? Thanks!! PB
  #2
Old July 12th, 2008, 10:44 PM
Default Re: 1980 Mercury 80 HP 4 cylinder hesitation...
  #3
Old July 13th, 2008, 11:21 AM
tredragon's Avatar
tredragon tredragon is offline
I have a similar, if not the same problem. Throttles up fine in Neutral but won't throttle up in either gear very often... Once it's running at higher RPM's though it purrs like a kitten, starts OK... I've read a few threads and see the words "spark" crop up a lot. I might have to check plugs, coils, etc.
  #4
Old July 13th, 2008, 04:25 PM
tredragon's Avatar
okay, so don't know if this will necessarily apply to your situation but my friends here recommended in my thread to check idle speed and mix. if you take the wraparound cover off the powerhead, you'll see a few bolts with plastic caps on them. they are usually labeled, my reco was to adjust idle mix 1/2 turn counter clock to richen up the mix. i'm going to try this with the muffs on and see if she throttles up in gear better.
  #5
Old July 14th, 2008, 07:28 PM
Thanks tredragon....but I don't think I need to adjust anything, because it doesn't always do it. It seems to happen after the motor warms up, and especially after running along slowly (<2000 RPM) for an extended period of time. Somebody told me I might have a reed valve problem. Do these stick intermittently, or? Don't know anything about them.
  #6
Old July 14th, 2008, 07:49 PM
TommyA TommyA is offline
It would be a easy test and would eliminate one easy to make adjustment to adjust the idle mixture screw out like tredragon mentioned in his post before doing a major disassembly of the engine to replace reed valves. Just a thought you might try!
  #7
Old July 15th, 2008, 12:07 AM
Thanks Tommy....I'd agree, but I don't like making adjustments for the sake of "trying something". This is an intermittent problem, so it seems to me that something is plugging or sticking.
  #8
Old July 17th, 2008, 01:35 PM
imported_Voyager imported_Voyager is offline
Have you tried squeezing the bulb?
It's possible that you have a fuel issue. I think the diaphragm fuel pumps are a bit marginal, especially at low speed. Perhaps after going slow for a bit, the bowls are getting low and the motor is starving when you throttle up...
It could be time to rebuild the carbs, or at least the fuel pump part of the carbs.
  #9
Old July 26th, 2009, 02:44 PM
Turns out it was just sticky reeds from improper winterization. Problem worked itself out with no intervention. Thanks!
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1980 Mercury 80 spark plug type fishdog4449 Mercury & Mariner Outboards 1 June 2nd, 2008 03:07 PM
1980 mercury 80 hp lower carb not sucking swarfmaker Mercury & Mariner Outboards 7 October 15th, 2007 03:47 PM
78,80 hp mercury,model 8oo 4 cylinder felderlostnspace Mercury & Mariner Outboards 2 September 21st, 2006 04:38 PM
Crank, no start 1980 4 cyl 80 hp dctucker Mercury & Mariner Outboards 2 June 30th, 2006 03:39 PM
1983 merc 80 hp slight hesitation Forceluver Mercury & Mariner Outboards 4 March 21st, 2004 08:14 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
