  #1
Old July 11th, 2008, 07:38 PM
j5ffx j5ffx is offline
Default slight misfire on #1 cyl mariner 40hp 2stroke
Hi to everyone, how do i trace this fault?
This motor (97 mariner 40hp 2stroke 2cyl 7041203FD) has a slight misfire on number 1 cylinder. it ticks over with a noticable misfire, if i pull the plug off #1 cyl it ticks over very well (sweet). if i pull #2 plug it continues to run but with a eratic misfire! it dosnt change when i rev it up a bit. it has got 2 brand new CDMs fitted, new trigger, new plugs, ht leads, carb kit and clean, compression test was all good =.
i have visually inspected the red stator, it looks good with no sign of a leak/melting, the reed valves are fine, the flywheel magnets look ok and the timing is good with the link and sync set up ok.
i have swopped the CDMs, plugs and i read somewhere to swop some green and white wires from the stator or was it the trigger? to try and move the fault to #2 cyl but it dosnt move. the fault is always on #1 cyl.
So can someone tell me the best way to trace the fault? im going to buy a DVA meter and then learn how to use it as i suspect it might come in handy either now or later on.
cheers jeff
  #2
Old July 20th, 2008, 01:20 PM
Default Re: slight misfire on #1 cyl mariner 40hp 2stroke
i found the fault, it was the rev limiter. i disconnected the BLK/YELL and BROWN wires from the rev limiter to cut it out of the equation and it then ran fine.
hope this helps others
regards jeff
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1974 115hp Johnson - Slight misfire at idle cfwolnia Johnson & Evinrude Outboards 0 June 30th, 2008 12:09 PM
1990 5hp 2stroke rough idling/misfire gatorman21218 Mercury & Mariner Outboards 4 January 27th, 2008 05:38 PM
slight misfire/ Ignition? Fuel? BigNiner19 Johnson & Evinrude Outboards 7 July 29th, 2007 08:52 PM
Early model 40hp 2Stroke cyl Mariner PACERll Mercury & Mariner Outboards 2 March 21st, 2005 01:33 AM
Overheat Switch Merc/Mariner 40HP 4 Cyl Moody Blue Mercury & Mariner Outboards 1 February 2nd, 2005 04:14 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
