  #1
Old July 10th, 2008, 10:39 PM
otsegony otsegony is offline
Default Hole-y 14' Starcraft Aluminum Boat
To All:
I bought a well-used early '80s Starcraft aluminum boat from a neighbor and would like to fix it up and get in on the lake. I went through the motor and got that running and now I am working on painting and carpeting the boat, nothing fancy, just trying to get it so it looks half-way decent. My problem is that there are 8-10 places below the waterline that either have been patched or had a mounting for a fish finder added. In each place a previous owner had put some substance that looks like silicone sealer, but is somewhat harder. As I am cleaning up the hull to paint it I have been pulling all of this old stuff off. My question is what material should I use to replace it? When I worked on a fiberglass years ago I used 3M 5200 and that seemed to work pretty well. Will that work on aluminum? Will it work in those places where there is an existing patch? Any help would be appreciated!
Garet
  #2
Old July 10th, 2008, 11:39 PM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
Default Re: Hole-y 14' Starcraft Aluminum Boat
JB Marine weld works great. http://www.jbweld.net/products/marine.php
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
  #3
Old July 11th, 2008, 10:52 AM
jennis9's Avatar
jennis9 jennis9 is offline
TD, we have the same issue with swiss cheese on the transom. We have plugged them but not with this method - so we are going to redo it and then repaint the bottom paint.
But I have read in other threads that you would want to fill the hole with 3M and then put the screw back in the hole and then cut the head off flush with the transom and sand. Your suggestion seems a TON easier... and I like that idea better.
But why would you use the JB Weld and not the waterweld? Is the two part product stronger? I only question this because in the other thread seemed a little more complicated.
  #4
Old July 11th, 2008, 01:06 PM
eavega's Avatar
eavega eavega is offline
When fixing my old aluminum boat, I found that if you are working seams, or around replaced rivets, the 3M 5200 works really well because it allows for a little flex without losing its adhesion or water-tightness. The JB Weld was brittle, and would fracture on a seam if there was some shearing force on it. When it came to patching holes in a sheet of aluminum, though, JB Weld was just the right tool for the job.
Just my experience with both products.
-Eric
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
14' Aluminum Boat Paints TheCompound Boat Restoration and Building 5 May 29th, 2008 07:44 AM
14' aluminum Starcraft "V" bottom reload Non-Repair Outboard Discussions 6 July 15th, 2007 10:27 PM
Removing seats in Aluminum 14' Starcraft dave524 Boat Topics and Questions (not engine topics) 5 February 25th, 2007 08:39 PM
7.5 HP on 14" Aluminum Boat?? garybli Non-Repair Outboard Discussions 11 January 15th, 2007 08:28 AM
Motor for 14' Aluminum Boat Ducats Non-Repair Outboard Discussions 37 May 31st, 2006 07:32 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
