  #1
Old July 10th, 2008, 05:54 PM
wwb1969 wwb1969 is offline
Default 1987 yamaha 225 excel oil fouling plugs after extended low speed operation
good afternoon i have a 1987 yamaha 225 excel in a 225 boston whaler with approx 700 hours on motor.This year i am having a problem with the motor oil fouling plugs after slow speed operation of about 1 mile.I live on a creek with a no wake zone that leads into lake ontario after slow speed operation i start to oil foul the plugs and the motor seems to be using more oil than normal.I have not touched the adjustment on the pump at all.If medium to high speed boat runs perfect no problems right up to 5300 rpms can the oil pump wear out internally with age to produce more oil flow? any help would be greatly appreciated thanks.
  #2
Old July 11th, 2008, 03:21 PM
gsyfishy gsyfishy is offline
Default Re: 1987 yamaha 225 excel oil fouling plugs after extended low speed operation
Most older model motors with external oil pumps, will pump different amounts of oil for different operating circumstances. It may mix the fuel and oil at 50:1 at idle and low trolling speeds, as you throttle up it will change. You may need to have the oil sending unit checked, and adjusted accordingly.
  #3
Old July 12th, 2008, 07:13 AM
rodbolt rodbolt is offline
if all the plugs are fouling I would not suspect the oil pump. if you have the original pump it should have 6 nipples pointing up, if you have the newer version it will have 3 on each side almost horizontal.
the early style pump had internal check valves the newr had inline check valves.
you will also need to check the low speed charge coil and the recirc check valves located on each cyl. its the little steel 90* nipples with small gray hoses. there are 6 of them.
if they fail plug fouling at low speed is the result.
manual shows an oil output test, I use a consumption test as well. use a marked glass or plastic tube and multiply the oil output by 6 and see if the running consumption is correct.
also check the TPS voltage for correct output.
  #4
Old July 14th, 2008, 08:55 PM
hello rod bolt i hope you would respond.you helped me on this same boat with the fuel airating but is was actually boiling do to the vaccum on the system.the nipples are all up i have a factory manual and as far as i can see it does not give me any procedure on oil flow to the carbs.also not to be a dumb *** low speed coil reference to the oil pump.any help would be greatly appreciated thanks wayne
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1987 Yamaha 225 Excel Oil Pump Problem wwb1969 Yamaha & Suzuki Outboards 2 May 15th, 2008 08:23 AM
99 yamaha 225 fouling plugs sfd971 Yamaha & Suzuki Outboards 0 September 2nd, 2007 12:02 AM
1989 225 excel yamaha retro oil pump jk1162 Yamaha & Suzuki Outboards 15 July 13th, 2005 12:35 PM
yamaha 1989 225 excel (oil from main tank draining back to remote tank . 9989 Yamaha & Suzuki Outboards 1 April 25th, 2005 07:08 AM
Yamaha 225 Excel (1987) Oil Buzzer Problem Bandaid Yamaha & Suzuki Outboards 3 January 16th, 2004 02:59 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
