  #1
Old July 9th, 2008, 10:50 PM
corzy corzy is offline
Default Water in the oil
Hi there, new to the forum, and my first thread isn't a fun topic.
Just wondering if anyone can give me some advise as i dont want to be taken by the company who winterized my boat (incorrectly)
I have a 25' , 1986 sea ray sundancer, with a 350 chev, 260 merc.
end of last season i rode it over to my trailer, didn't notice any funny sounding noises that i can remember, trailered it to the shop, they winterized it, changed the oil, and we stored it for the winter.
this season, charged the bateries, replaced the drain plug and started the motor with the muffs on. Ran OK, took it to the ramp, and drove it over to the marina, while on my way noticed a knock in the engine. checked the oil (didn't do this earlyer as they changed it during the winterization) and sure enough it was milky. had the oil changed, started it up again and instantly milky. took the boat to the marine shop, where they pulled the motor, opened up the top end and found nothing wrong with the heads or block, so we sent it to the compay who winterized it (not impressed we didn't take it there first) and now waiting for there millright to look at the block closer (i guess)
the guy at the marina was asking foolish questions to find our boat engine knowledge like did you check your antifreeze when you got to the marina and stuff like that. Were not totally in the dark but also not mechanics.
the rings didn't have any score marks on them and no burnt spots inside the cylinders.
the guy who winterized assures it wont end up being the cause from water freezing, but could't come up with an answer to where the water came from.
any advise would be really appreciated.
thanks
Corzy
  #2
Old July 10th, 2008, 08:16 AM
nlain nlain is offline
Master Chief Petty Officer
Default Re: Water in the oil
I can only think of a couple of things to cause your problem, crack in the casting, block or heads, possibly rust through form water jacket which I doubt. There are many engines that run in salt water, not sure what you are in, that last as long or longer than yours and usually have a mechanical failure and get rebuilt. If you had a water cooled oil cooler you would have oil in the water not water in the oil since oil pressure is greater that water pressure. I go more with the crack in water jacket to the oil, either block or heads. If manifold or riser problem you would have water on top of the piston and not an instant mix to the oil, you would have a hydro lock situation there. You may want to get an outside party involved to check behind everybody to be sure of the correct diagnosis. Someone of your choosing, not either of the two places already involved, and not someone they recommend. If no problems last year then I would feel like you that improper winterize is the culprit. It would have been good if you had checked the oil before ever starting the engine this year. I hope it works out in your favor.
__________________
http://myboat.wikispaces.com/
2004 Sea Ray 185 Sport, 4.3L,190, Alpha
1994 GMC 4X4 1500, 5.7L
  #3
Old July 10th, 2008, 10:05 PM
thanks alot for the info, I appretiate it.
__________________
Corzy
1996 Baja sport jet 90, 90 horse mercury
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Water In gear Oil & water pump replacement JRose_1989 Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 5 June 15th, 2008 12:49 PM
old oil, or water in oil...chocolate color spartanpele Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 25 June 18th, 2006 11:29 AM
old oil, or water in oil...chocolate color spartanpele Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 1 May 23rd, 2006 03:37 AM
140 merc water in oil, lots of rain engine sat in water sylvan22offshore Mercruiser, OMC, Volvo & other I/O & Inboard Engines & Outdrives 29 March 21st, 2004 05:16 AM
85HP V4 Johnson Oil leak lower unit and water in oil darwinh11 Johnson & Evinrude Outboards 3 October 10th, 2003 07:29 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
