:confused: Chrysler 75 hp/ 756 HA/ issues
ck85abc3
Re: :confused: Chrysler 75 hp/ 756 HA/ issues
You are going to have to explane more before someone tries to help.
cabinetman16
I need help with no spark going out to plug wire got spark coming in to the points and button but nothing out to the plug wires at bottom of distributor.Replace distributor and points and timed enigine but still nothing.Tried to check the bottom where the wires connect and have spark only when you try to start enigine then turn key off then volt meter reads spark but nothing when turning engine over.Can anyone Help!!
