reelfishin
- Mar 19, 2007
- 3,043
I am in the process of swapping one of my motors over to another boat, it's a 1985 90 HP which I plan to add power tilt and trim to, a new prop, and a complete tune up. The motor has always run great with no issues but I figure now was the time to freshen up the tune up and add the tilt/trim unit since it's off already. Having bought a fancy new Snap On compression gage I figured I'd check that while I was at it. I checked several of my motors I have here, including a few I have stored for future use. What I found surprised me, the 90Hp has the lowest of all compression readings, I got 124/123/124/121.
I also checked a well used 1977 135 hp I have and got 139/131/134/132, and my 1985 70hp, which was 142/141/141.
I also checked another older early 70's V4 I have here and got 145/144/144/141, and a 1985 115 hp that reads 120/121/119/118.
I'm used to dealing with auto engines and seeing higher readings, as well as a few Mercury motors I have that have compression in the 145 to 150 range.
I realize that some of the smaller two strokes run with a lot lower compression, but what's normal on a 1985 90HP?
What should I expect to see on these? do some V4's have more compression than others? It seems that the lower hp motors all seam to have less compression. One local dealer said that the 85 through 115 motors always read lower than the 135/140 motors. For comparison sakes, I checked a buddies motors, a pair of 1984 115s and got between 121 and 125 on all cylinders, both of those motors have two fresh power heads last fall.
