I have a mid 70s Chrysler 60 with two Tillotson carbs. The factory manual says to turn idle adjustment screws on carbs to set idle, but shows no picture where these screws are and I can't seem to find them. Can anybody help me? Thanks.
Re: Where are idle adjustment screws on Chrysler 60?
look above the choke on the carbs. On the upper face you will see a slotted screw just inside the carb. That is the adjustment. The pic below is not for your motor but you can see it part number 15. This carb is real similar to yours.
