Re: Mariner Fuel Consumption
Generally, a carbureted 2 stroke burns about 1 gallon per hour for every 10 horse power generated. That means at full throttle, your 150 horse Mariner will burn 'in the neighborhood' of 15 gallons per hour. You dont say your boat size, weight, prop pitch, etc so estimating the power needed at various speeds is impossible.
Best fuel mileage usally occurs between 3500 and 4000 rpm on these engines, assuming you are propped correctly tp allow the engine to run to rated rpms (probably 5800 rpm on this engine).
__________________
I can't understand why OMC went broke...I know I spent enough to keep them in business.
