1989 mariner 45 how do you get at the powerhead lower gasket (pics included)
how do you get at the power head lower gasket? i removed the power head but something is holding the plate that is on top of the lower gasket. i do not see anything else to loosen on top. could this plate somehow be attached to the lower unit? the first pic shows the plate that i need to remove (the black hole is the exhaust tube that is attached to the plate). the second pic is a close up i am pointing at the lower gasket and you can see that i can slide the plate from side to side a 1/4 of an inch. thanks for the help (i hope)
Re: 1989 mariner 45 how do you get at the powerhead lower gasket (pics included)
Remove the screw from the shift linkage and lift the linkage and shaft out of the mid section then the exhaust plate will tap loose and can be lifted out.
Quote:
thanks for the quick reply. i will not be able to get at it again untill wed. so i'll let you know how it goes then. so you are saying that the shift rod will pull all the way out? because i had it up about 12" but it did not seem like it wanted to come all the way out. and when you say "tap loose" do you mean the exast tube is held in place by a press fit and i am just lifting it out by seperating the exast plate from the top of the gear shaft housing? thanks again!
The shift rod should just pull out the top and the gaskert for the exhaust plate is self adhering and has the plate stuck down, ussaully tapping on the side of the plate will loosen it.
i pulled the shift rod out. the plate is free from the lower gasket but still attached to something inside of the drive shaft casing. the exaust tube is part of this exaust plate as well as what i think is the water tube. here is a link to the part drawing: http://www.mercruiserparts.com/Show_...+Shift+Linkage
do i need to pull off the lower unit to get at whatever it is that is still attached to the plate?
Yes, if it's loose at the gasket it's probably the w/tube, I drop the gear cases when pulling the powerheads nornally so did not even think about it.
any tricks to taking off the lower unit? thanks again i am going at this for the first time and your assistace is very much apreciated. can i tilt the motor up some or do i need to keep it verticle (i ask becase the skeg is touching the ground) i can dig under it if i need to.
i searched the forums and found the one by "mariner45" about his stuck lower unit. i am pretty sure i have the same OB, so i'm looking for 5 nuts. do i need to shift it into forward?
