Re: trying to understand what this means on my prop
20 ? will be pitch. In theory the boat will move forward 20? for each revolution of the prop. In reality all props have some slip, appx. 10% is reasonable. Lower pitch will be a lower gear ratio, better holeshot, less top speed. The most important question ? is your boat attaining recommended RPM at wide open throttle. Each engine will have a recommended range at WOT. For instance, my F150 recommends 5500 ? 6000 RPM at WOT. Pitch changes should only be made to achieve this RPM at WOT. My boat will spin a 21P lightly loaded at 55 MPH, but with a boat load of people I?ll switch to a 19P to maintain 6000 RPM at WOT, but top speed falls off to about 50 MPH. You will need to know your engine?s recommended operating range, your current prop pitch, and your current WOT RPM before consider changing pitch.
