1968 Johnson 55 HP lean rich setting
aaromba
Can anyone tell me how many turns out the rich/lean setting screws should be before I put the adjusting mechanism back on. IOts a 55 HP model TRL-10R. I found them about 1 turn out and once the adjustment mechanism it will only allow you 1/2 of a turn. Any ideas will help. thanks
aaromba
Re: 1968 Johnson 55 HP lean rich setting
I have only one knob that will lean it out or make it run richer. Its under the fold down flap on the front of the motor. It's marked richer with an arrow and lean with an arrow the other way
