  #1
Old July 7th, 2008, 07:10 PM
Kromrider Kromrider is offline
Default Fouling plugs ignition problem 1975 135HP Evinrude
I recently bought a 19 foot boat powered by a 1975 135 HP engine. At first the engine ran fine although it was a little hard to start. After about 20 minutes the engine started to loose power and we limped back to the dock and brought the boat home. We pulled the plugs and all four plugs were fouled. we changed the plugs and took it out a second time and had the same results ran okay at first but then lost power and we limped back to the dock. again all four plugs were fouled. I checked over the wiring and everything seems to be clean and tight. I am thinking it may be some type of ignition problem or loose wires as the problem the second time out started after we crossed some wakes (bumped). Any suggestiions?
  #2
Old July 7th, 2008, 07:29 PM
ezeke ezeke is offline
Default Re: Fouling plugs ignition problem 1975 135HP Evinrude
Using a 50:1 87 or 89 octane fuel to TC-W3 oil that is a synthetic or synthetic blend will help. BRP XD-50 has a built in carbon treatment called Carb-X that will help you to keep the system clean; synthetic oils have a higher flash point.
First, do the de-carbon treatment to clean up your engine because if the plugs are fouled, so are the rest of the firing chambers: http://forums.iboats.com/showthread.php?t=158076
Make sure that your thermostat is working, because nothing fouls quicker than a cold engine in my experience.
If you don't use the Champion UL77V plug, I would highly recommend that you use Champion QL77JC4 gapped at .04 until you get back to us with your compression readings.
  #3
Old July 14th, 2008, 12:23 PM
Okay i spent all day Sat working on the boat. Seafoamed the engine both ways. Did a compression test on the motor and all four cylinder were within 5 pounds of 150. I used the fuel cell I bought to rule out any gas tank issues. I got 6 gallons of fresh gas mixed with TC-W3 synthetic oil. I changed the plugs and headed to the lake for a test ride. Engine started right up and we did a full throttle run accross the lake with no problems. We stoped to put out the tube and had a little trouble restarting the engine. I tried to go and the engine would stall as soon as we increased the throttle. we were able to restart the motor and limped it back to the dock. any time we tried to increase the rpms it would stall. all four plugs were fouled and I a convinced it is some kind of ignition problem. Any suggestions?
  #4
Old July 14th, 2008, 01:38 PM
Have you had the thermostat changed?
Look on the top of the engine block, next to the lifting eye, and see if there are wires running from there to the terminal block.
Also see how many wires are running from the choke solenoid to the terminal block.
The four coils on the the rack at the top are subjected to a lot of heat and are a frequent problem. They can function normally when cold and break down when warm. If they are discolored, cracked, swollen or melted, it would be good to replace them. The newer replacements are better.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Proper Plugs for 1975 135HP Randyg123 Johnson & Evinrude Outboards 5 May 8th, 2008 07:03 PM
1975 135HP no spark with plugs installed, PP4? RobsTV Johnson & Evinrude Outboards 11 May 20th, 2006 06:28 PM
problem with evinrude 6 horse fouling plugs pruble Johnson & Evinrude Outboards 8 April 25th, 2006 02:42 PM
Alternate plugs for a 1975 135hp? fseventy Johnson & Evinrude Outboards 3 April 7th, 2006 10:27 PM
ignition problem on '73-135hp Evinrude dulind Johnson & Evinrude Outboards 3 August 5th, 2003 10:03 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
