  #1
Old July 7th, 2008, 05:47 PM
old boat NC old boat NC is offline
Default 2002 Yamaha 15HP 2 stroke carb mystery?
I just bought a 2002 Yamaha 15HP 2-stroke that had been sitting for several years in a garage. Obviously, it wouldn't start... the carb was all gunked up.
No problem, I took the carb apart, carefully cleaned all ports, valves, float needles, etc. Re-assembled, put back on motor, used fresh oil/gas, and it started on the first pull and ran like a champ in my driveway with hose attached.
However, once I got it on the water, when I shifted it into forward, and the throttle is opened wide open, the engine runs like it is starved for gas. HOWEVER, if I pull the choke open about 1/2 way, it runs wide open perfectly! The engine idles and goes into forward and reverse just fine at idle speed. It is only when I open it up in forward that it stalls...
(The vent to the fuel tank is open & the fuel pump looked great when I cleaned it.)
Is there an adjustment I am missing? I only see one adjustment screw on the side of the carb and it doesn't seem to change anything. Or did I not adjust this screw out enough? I only opened it maybe three turns past there it was. (About 5 turns total.)
I think this is something really simple I am over looking. Can anyone help?
Thanks!!!
John
  #2
Old July 7th, 2008, 06:16 PM
JB's Avatar
JB JB is offline
Default Re: 2002 Yamaha 15HP 2 stroke carb mystery?
My first thought is that the high speed circuit is not completely clean, but I prefer to do some fault isolation before tearing into the carb again.
With the engine at idle, disable each spark plug in turn. Each should cause the idle speed to drop, by a similar amount. If that doesn't happen you may have a weak or bad cylinder. A compression check would be in order.
Keep in mind that many sick engines will "run like a champ" with no load on them, sometimes on one cylinder.
If the compression checks out on a weak or dead cylinder, check the spark for a hot, blue spark that can jump at least 5/16".
Less likely but possible causes are a bent or broken reed or a leaky gasket preventing scavenging pressure in the crankcase. Gaskets tend to dry out in long storage.
If none of the above turn up a culprit I would go into the carb again, with particular attention to the orifices into the carb throat.
Good luck, and let us know what you find.
__________________
RED SKY at night. . .
JB
  #3
Old July 7th, 2008, 06:41 PM
Thanks for the thoughtful suggestions...
I will check out the spark when I am at the boat next weekend.
What exactly is the "high speed circuit"? I've never heard that term before.
My therory was that I missed something in the carb when cleaning it.
Do you know why it runs so well when the choke is pulled out slightly?
Thanks again for your help.
Also, if this helps, the motor has only ever been run in fresh water. And the the guy I bought it from said he only ran it a few times before storing it in his garage ... he claims 10 hours on the engine, max. Something I believe after looking at the spark plugs, and general condition of the engine. It is spotless.
John
  #4
Old July 7th, 2008, 08:37 PM
JB's Avatar
JB JB is offline
The "high speed circuit" is that system in the carb that supplies fuel to the airstream when the throttle plate is fully, or near fully, open.
It differs a bit from one type carb to another, but the orifice into the carb throat is usually located right in the narrowest part of the venturi.
__________________
JB
  #5
Old July 8th, 2008, 07:59 AM
locallawoff locallawoff is offline
Smile Re: 2002 Yamaha 15HP 2 stroke carb mystery?
Gidday from down under,When you strip the carby and have access to a air compressor use it to blow all the holes you can find.Locallawoff
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
yamaha 2002 115 2 stroke njohnson1960 Yamaha & Suzuki Outboards 11 October 3rd, 2007 05:26 PM
2002 Mercury 50 HP 2 Stroke Carb Questions baldeaglejones Mercury & Mariner Outboards 5 September 10th, 2007 01:09 PM
Yamaha 115 4-stroke oil mystery mish Yamaha & Suzuki Outboards 2 May 28th, 2007 03:50 PM
2002 yamaha 15hp 2 stroke help needed rosscopeeko Yamaha & Suzuki Outboards 2 November 25th, 2006 05:27 PM
Yamaha 225 4 stroke 2002 fyock Yamaha & Suzuki Outboards 6 September 9th, 2003 03:39 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
