Re: 78 105 Magnapower - Gear Box?
That's a one piece lower unit. I thought Chrysler did not change to them until 1979 1/2.
Since it can be a royal witch with a "B" to get the yoke back in place, before you disassemble the lower unit move the shift rod to see if it will engage the gears. if it does not, then disassemble. The shift rod should be screwed all the way down into the Steel shift yoke inside the lower unit and backed off only enough to line up the holes with the holes in the upper shift rod (less than 1 turn)
Anyway, behind the prop there should be an anode --fresh water or not. It is held onto the spool by two screws. Beneath the anode there are four 5/16 bolts with 1/2 inch heads. You unscrew these bolts and using some all-thread 1/4 -20 screwed into the anode screw holes, you fabricate a puller. You pull out the spool. If it has not been removed in some time, it may be difficult.
Once you have removed the spool (called that because it is shaped like a thread spool) you will see an aluminum plate with the four holes for the 5/16 bolts and four other curved holes in it. Around the perimeter of this plate are two semi-circular clips that hold it in place. You reach in with a screwdriver and wedge it into the tapered ends of the clips, then pop them out.
Now, a good yank should remove the prop shaft, the bearing carrier, the dog clutch, and reverse gear as an assembly. The brass yoke should stay in the shaft groove if it was there to begin with and you have not been too rough with your handling. If you can't pull it out by hand, use some 5/16 all-thread and nuts to make a puller. Once the shaft is out, check the condition of the six dogs on the clutch and the three dogs on each drive gear. leading edges should be fairly sharp--within reason. If they are well rounded, they tend to pop out of engagement and will need to be repaired.
Forward gear and the drive shaft and pinion will stay in the housing --not necessary to remove them unless there are other problems--like repairing the drive dogs.
Clean residual oil out of the gear housing and then shake it around a bit to dislodge the brass yoke. It will come out the center hole in the forward gear.
Now, if it is broken, you will need to buy a new one--they used the exact same part for all three and four cylinder lower units since the late 1960s. Only difference was some came with a steel yoke (which I have never seen).
When you go to replace the yoke, use a good heavy grease to keep it in the slot. Then with the bearing carrier and reverse gear removed, slide it through the forward gear center hole. Here's the hard part. There is another steel "yoke" which is held in place by the famous side screw in the nose of the gearcase. pull up the shift rod all the way and you will be able to see the slots in this yoke. The two pins on the side of the brass yoke MUST engage these slots--It may take you several tries--and several references as to the parentage (or lack thereof) of the gearcase. Invocations and imprecations help your mental state.
After positioning the prop shaft in the forward gear move the shift rod and see if you can see the dog clutch moving forward and backward on the prop shaft. Do this with the lower unit horizontal since the steel yoke can move it up and gravity will move it down if the unit is vertical.
If it functions properly, replace rear gear, bearing carrier, circlips, spool and anode. Use some anti-seize on the O rings on both ends of the spool to help it come out easier next time. Buy new O rings--cheap insurance against leaks. Torque the four 5/16 bolts to 160 inch pounds. Be sure to not lose the small O rings under the washers. Better to buy new if any doubt exists about their condition.
