kylejohnston1
- Sep 19, 2006
- 6
I recently bought a 2000 Firsher deck boat with a 4.3L Mercruiser. The boat started and ran fine before I trailered it home. Once I got it home, I tried to start in in the driveway and the I heard the starter whining and the motor was not turning over so I went and bought a new starter.
Upon removing the old one, I was surprised to find that it was not very tight and the bolts were very easy to loosen. I inspected the old starter and some of the teeth were chipped and grooved. I pulled the spark plugs and inspected the flywheel all the way around...looked to be in good condition with no missing or chipped teeth (big relief).
I installed the new starter and when tightening the bolts back up, I was not able to get them tight at all. One bolt gets somewhat tight but the other will start to get tight and then slip. I was able to get them tight enough that the starter would not move. At this point, I cranked the boat up with no problems and launched it for a test run.
The boat ran great on the water until I turned it off and tried to start it again. Apparently the bolts had loosened themselves up and the starter was loose again, and no longer able to crank the boat. Once I got home, I tightened the bolts again and the boat cranked right up.
So, the problem is that I can't get the bolts tight enough when installing the starter and they become even looser when the boat is running in the water. My new starter did not come with new bolts so I had to reuse the old ones. I thought maybe new bolts with loctite would solve the problem but the old starter seems to have had the same problem before I ever removed the bolts.
My next fear is that the threaded holes in the engine could be stripped. If this is the case, what are my options? I thought about using a tap to enlarge the holes to the next largest bolt size? I also thought about using Helicoil inserts? Has anyone ever tried either of the above methods or any other for that matter?
Sorry for the long post...just wanted to give all the details. Thanks in advance for any suggestions or input!
Kyle
Kyle
