  #1
Old July 5th, 2008, 08:00 PM
halder.fireifighter halder.fireifighter is offline
Default 115hp evinrude no reverse
Was out in the lake this weekend and went to dock the boat and had no reverse . the shifter is moving in to the reverse area. What could be causing the problem . Another thing i found was out of the water when i put it in to reverse the prop spins like it is in neutral. what could be the cause and is it expensive to fix??
  #2
Old July 5th, 2008, 09:37 PM
Sherman Sherman is offline
Default Re: 115hp evinrude no reverse
I would disconnect the shift cable from the motor and see if you can shift into reverse by hand. If so you may need a new cable which are cheap. If it will not go into reverse by hand it could be a lower unit problem. Not cheap.
You may need to turn the prop by hand to get it to engage if the engine is not running.
  #3
Old July 5th, 2008, 10:21 PM
Spacesin Spacesin is offline
adjust your linkage ... i lost forward gears but had reverse and it was just that quick .. very happy to say adjusted the linkage through the exhoust panel and it is fine
  #4
Old July 6th, 2008, 01:17 AM
I have tried to shift it in to reverse and it moves like it did before. when I have it in reverse and spin the prop I have a clicking sound. I am sure the motor has not had the easiest life it is a 1977 115 hp
  #5
Old July 6th, 2008, 10:51 AM
tashasdaddy's Avatar
tashasdaddy tashasdaddy is offline
remove the shifter cable at the engine, and shift manually at the motor. sounds like a cable, forward is a pulling motion on the cable, reverse is a pushing motion, if the cable is going bad, it cannot push the motor all the way into reverse.
__________________
FLORIDA GATORS
TEBOW Country
See you at the 2nd Florida get together, April 23-25, 2010. Crystal Springs, FL
http://forums.iboats.com/forumdisplay.php?f=13
we all need to support iboats marine store when ever possible. you get, competitive prices. fast shipping, top notch customer service. also it provides us, this great FREE forum.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
1997 Mariner 115hp...lost my reverse greg1865 Mercury & Mariner Outboards 2 April 28th, 2008 05:35 PM
1974 115hp not going all the way into reverse. TimDollar Mercury & Mariner Outboards 5 September 3rd, 2006 09:49 AM
1976 115hp evinrude, No reverse! fro_one Johnson & Evinrude Outboards 5 August 28th, 2005 08:05 PM
Reverse on 1150 Mercury 115hp csmall06 Mercury & Mariner Outboards 1 August 12th, 2004 10:18 AM
No reverse on 115hp Merc. 1977 OB bfred1 Mercury & Mariner Outboards 3 May 1st, 2001 07:45 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
