Hi everyone. My father, grandfather, and I are in the processes of replacing the engine in a 1988 Bayliner Capri with a 5.0L V8 Chevy 305 with a Cobra outdrive with mechanical shift.
We got the boat with a hole in the water jacket last summer. After trying to JB weld the piece of block back onto the engine block (which only held at idle) we decided to buy new replacement block. Sorry I dont know the exact terms but it already had the pistons and valves in it, we just need to replace the upper exhaust and what not.
The engine swap went without a problem, until today. It was time to place the stern drive back on to the transom. We used the GM/OMC Alignment tool to make sure that everything was aligned before we tried to slide the drive shaft into the unit. However, we cant seem to get the outdrive to slide back onto the transom. Its almost like we are hitting something inside the boot that the gimble bearings slide into.... We tried to turn the engine manually with a breaker bar/wrench, thinking maybe we were up against the splines in the coupler but you can still slide a piece of plastic in between them. So maybe the gimble bearins are hanging up inside that boot thing.
Second problem:
We tried to place the out drive in gear by pushing up on the shift connector on the back side of the outdrive, it moves up into gear, but we cant turn the prob at all. We placed a very large screw driver in between the gimble bearings and tried to turn the shaft, but no go. Where are we hanging up? its almost like there is a pin or something stopping it from turning over. We can place the gears back into the neutral position and the prop will spin freely.
Attached are some pictures of the engine/outdrive and transom.
Thanks for any help! sorry if this post is confusing or doesn't make sense.
-Jared Bennett, Oregon
Here is a picture of the Original engine with the hole in the water jacket
This is a picture of the new block.
Transom/outdrive 1
Transom/outdrive 2
