Re: Very weird problem with 20hp johnso... White Smoke!
Aren't most Jonhsons 50/1? How many times did you do the decard thing? I just did mine with the Seafoam decarb method three times and it smoked out the marina, but runs pretty clean. If it's doing it more at low RPM
make sure air/fuel mixture is set right. My 94 8HP called for three turns out. Went 3 1/2 before it really cleared up. But, went out fishing and after a while engine would lose RPM's and start to smoke. After pulling off the cover and sitting there watching saw that the choke pivot bracket due to vib's would start to move slightly opening the choke. If I held it in closed position RPM's would start to come up and smoke virtually stopped. Don't know if your's is doing same but worth checking out. Fix was to put in another washer behind bellcrank screw to tighten down its movement. Now stays at constant RPM with minimal smoke.
Yeap, it`s a 50/1. I did the decarb thing once (this year) because the motor was setting in the garage. My motor is doing the same thing, at high rpm, there`s no smoke. Then, when I lower the rpm (around the idle speed), white smoke starts to come out for about 5minutes than stops. When I give the motor some gas and reduce it again, white smoke appears than disappear. However, when I hold it in closed position, the RPM don't varies (which I think is good).
Another thing, it`s normal to have water coming out of the exhaust right?
Thanks
