  #1
Old July 4th, 2008, 07:35 PM
RobertMac RobertMac is offline
Default 90 Mercury 50 HP won't start
The key was apparently left on last year, and now it won't start. I've replaced the switch box, regulator, rectofier, spark plugs, and batteries. It has a quick silver throttle. It turns over, but still won't fire. Help!
  #2
Old July 4th, 2008, 09:30 PM
JB's Avatar
JB JB is online now
Default Re: 90 Mercury 50 HP won't start
Hi, Robert.
Welcome to iboats.
Replacing parts is the most used, most expensive and least effective troubleshooting method known to man. I guess you know that now.
Go to the Engine FAQs and do "Outboard won't start". Let us know what you find.
__________________
RED SKY at night. . .
JB
  #3
Old July 5th, 2008, 03:13 AM
I looked at the FAQs prior to posting, and checked again to make sure I hadn't missed something. The postings on 50 HP Mercury not starting seem to deal with fuel issues, and I know mine's not a fuel issue; I have no firing at all. And I didn't find any issues related to leaving the key on.
  #4
Old July 5th, 2008, 08:36 AM
JB's Avatar
JB JB is online now
That sounds like you did a search of previous posts on the topic, Robert. A very good idea.
"No fire" can be a bit ambiguous. Do you mean "no spark" on any cylinder?
How, exactly, do you know it not a fuel issue? What happened when you squirted fuel mix into the carbs?
__________________
JB
  #5
Old July 5th, 2008, 11:34 AM
Checked all spark plugs with tester, but no spark on any cylinder.
After priming carbs with primer bulb, I sprayed WD-40 into the carbs and nothing happened.
  #6
Old July 5th, 2008, 11:52 AM
JB's Avatar
JB JB is online now
WD-40 used to be an excellent starter fluid, but not any more.
It used to use propane as a propellant and was labelled "Extremely Flammable". That worked very well as a starter. There may be some of that "NOS". If you can find it hoard it.
Several years back they switched the propellant to CO2 to make it "safer to use" and changed the label to merely "Flammable". I will still burn, but does not make a good starter anymore.
Well, no matter. You have proved that there is no spark, so getting spark is the next step.
I don't know enough about Mercs to give you good advice on the ignition system. If you have a factory Service Manual it probably has some trouble isolating procedures you can use.
Maybe a Merc-spert will come along soon.
Good luck.
__________________
JB
  #7
Old July 5th, 2008, 12:26 PM
CharlieB CharlieB is online now
Your Merc has a mag ignition, the switch grounds the black wire with a yellow trace to kill the motor. Leaving the key 'On' will only serve to run the starting battery dead, no harm done to the ignition.
Check to be sure that your safety lanyard is installed correctly, if no spark still then check the blackw/yellow wire with an ohm meter for continuity to ground, if none then you will need a DVA meter and follow the testing listed in the CDI Ignition Troubleshooting Guide to determine which component is at fault.
  #8
Old July 6th, 2008, 03:03 PM
Stator tested at 500ohms; replaced stator, and it now works! Thanks to JB and CharlieB for all the help.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Help Mercury 90 hp won't start Singing Boat Guy Mercury & Mariner Outboards 6 July 27th, 2007 06:55 PM
1988 90 HP Mercury Outboard - Won't Start imported_dgordon Mercury & Mariner Outboards 6 August 12th, 2006 10:49 PM
50 hp Mercury won't start when cold mousley Mercury & Mariner Outboards 7 July 18th, 2006 08:16 PM
1982 50 hp Mercury won't start in neutral belgianbuctail Mercury & Mariner Outboards 0 September 8th, 2003 08:01 PM
my 50 hp mercury wont start bassinalways Mercury & Mariner Outboards 1 March 16th, 2003 03:22 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
