Hello All, I am a new member here. Well I have a 85 or 86 70HP Evinrude that gives me problems after idling. Seems the carbs load up and when giving some throttle, the motor does not respond when advancing the throttle. I return to neutral, use the choke lever to run up some RPM's, seems to clear the carbs, and the motor runs fine. It's every time after letting the motor idle for any length of time.
What do you think this problem can be? I am puzzled.
