  #1
Old July 3rd, 2008, 12:56 PM
rterry rterry is offline
Default Yamaha 225 4 stroke fuel problem
I have a 4 year old Yamaha 225 4 stroke. I have had several problems with the engine stalling. On restart it sputters but will not run even after pumping up the primer bulb. It's been in the shop twice. The fuel/water separator was replaced the first time and the second time the mechanic said he found a kink in the fuel line which he corrected. But the problem persists. The last time it stalled it did restart after pumping up the priming bulb, but I have lost confidence in this engine. I boat on the Cheasepeake Bay and an unreliable engine is a BIG problem. I'm considering putting in another fuel line and bypassing the fuel/water separator on the theory that there is too much pressure drop in the fuel line to the engine. Any ideas?
  #2
Old July 5th, 2008, 12:43 AM
ricwing ricwing is offline
Default Re: Yamaha 225 4 stroke fuel problem
I had a fuel problem with my 03 f225 would only stay running if you pumped the bulb,stop and it would die. Ended up being the secondary fuel pump. turn the key to on position and see if you can here it run, it will only run for a second or two. This is an expensive guess.
  #3
Old July 7th, 2008, 08:29 AM
rodbolt rodbolt is offline
find a real dealership and quit guessing.
ALL yamaha dealers were shipped a fuel system tester as part of the essential tooling, your not asked if you want it or not you just get it and are billed.
this tester allows for checking fuel system vacum with the hull on a trailer and the engine off.
its essential.
then on to the electric lift pump, this is the externally mounted pump, it runs 10 seconds on and 20 seconds off at low speeds, it can be tested with a fuel pressure test guage at the output side once the supply side is tested, it can also be checked electrically with a multimeter while testing the output.
once the low pressure fuel side is confirmed or eliminated repost with the test results.
use the Yamaha dealer locator for your area and find a shop with a master tech or at least look for the school certs on the wall for 4 stroke,electrical and fuel systems.
there are a few other reasons for sputtering and stalling at idle, some are difficult to find but not impossible.
  #4
Old November 1st, 2008, 01:48 PM
mt799ph mt799ph is offline
these all sound very familar, my 02 F225 does the same thing. i have been told it may be due to a vapor lock. I just found out about a technical bulletin that Yamaha sent to the dealer on 9/23/03. They have a vapor recovery kit that is suppose to cure it. of course, mine is out of warranty now and they want $500 to install the kit. I think they may be in for a little battle with me as no one told me about this earlier. this is not a new issue for me.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
Yamaha 225 four stroke problem To Blessed Yamaha & Suzuki Outboards 1 June 11th, 2008 04:01 PM
Yamaha 225 2-stroke power problem mcm114 Yamaha & Suzuki Outboards 2 July 5th, 2007 10:19 PM
Yamaha 225 four stroke r/pm Problem trouble TS Yamaha & Suzuki Outboards 1 October 21st, 2005 06:21 PM
Fuel consumption on Yamaha 225 4-stroke Baitbucket Boat Topics and Questions (not engine topics) 2 April 2nd, 2004 11:42 AM
Yamaha 225 Four Stroke Fuel Injector gmburkhart Yamaha & Suzuki Outboards 6 June 9th, 2003 06:20 PM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
