still no spark
Status
Not open for further replies.
ram4x4man33
I have a mercruiser 3.0 4cylinder engine. I am not getting any spark from coil to dist cap, or to plugs, or at points. I am in desperate need of help if anyone can help me
oldyota
Re: still no spark
Check to make sure that kill switch is not causing the problem, make sure that its in neutral.. Shift it back and forth a couple of times and back to neutral... Other than that maybe the key switch, solenoid wire may have come loose... Just trying to give some help out....
Don S
Re: still no spark
You already have one post on this problem. Let's just keep it at one and use the original thread.
Status
