  #1
Old July 3rd, 2008, 12:01 AM
slyclops slyclops is offline
Default Info requested on transducer mounting
I just purchased an 88' SeaRay 18' "Seville" Bow Rider/Outboard. I would like to mount a "In-Hull" (not thru-hull) transducer in the bilges. Has any of you ever done this? Does it work? All suggestions and advice appreciated.
Thanks.........
  #2
Old July 8th, 2008, 09:35 AM
nlain nlain is offline
Master Chief Petty Officer
Default Re: Info requested on transducer mounting
I had a 87 17 Seville with 3.0L IO, I never mounted the transducer but it lay in the bottom, I would pour water to cover it and it worked fine. You can do it and it will work, I was told to get epoxy and mix, pour in bottom and set transducer in it, just be sure there are no air bubbles in the epoxy as that will cause problems with the transducer reading.
__________________
http://myboat.wikispaces.com/
2004 Sea Ray 185 Sport, 4.3L,190, Alpha
1994 GMC 4X4 1500, 5.7L
  #3
Old July 26th, 2008, 08:02 PM
Where in the floor did you lay it? On my boat, there is a ski storage area in the floor that has a small square recesed area, but I'm thinkin' there is 4-6" of fiberglass between this recesed area and the "V" of the boat, so I'm countin' that out. The only other place would be in the "Cubby" area (Under the outboard mounting/swim platform) where the bilge drains, I could mount it on either side of the bilge pump (which cycles "ON" every two mintes to test for water), so I am sort of scared it might throw some kind of interference into the transducer beings it is mounted so close? I have not removed the fuel tank floor cover to see if there are any recese's that might permit the transducer to be mounting in that area. I was hoping someone had the same boat as me and did the "in-hull" mounting thing and could walk me through it (hey, no harm in trying, right?)Thanks......Slyclops
  #4
Old July 28th, 2008, 08:23 AM
I layed it in the bilge under the engine, with the IO the engine is of course inside the boat with access below, it made it real easy for me, do you have access to the bottom of the hull that far back in your boat. From your post it sounds like you may have access. I was told to mix up two part epoxy and set the transducer in it, just be careful and not have air bubbles in it. You may want to put a float switch on the bilge pump, not sure if it would cause problem or not.
__________________
  #5
Old July 28th, 2008, 09:28 PM
gstanton gstanton is offline
My original one was mounted under the engine (I/O), right beside the auto bilge pump. Not a problem until the Lowrance unit itself went bad and the new unit needed a different transducer. I mounted it just forward of the engine with quick setting epoxy, as in the instructions. Also... that was the only place the cable would reach. The cable is shielded, so that should eliminate any electrical interference. You don't want it too far forward, or the turbulence from underneath the hull, when under way, might cause reading problems... just like you don't want it too far astern where the prop turbulence might mess it up.
Bottom line - the cable length will/might determine where you put it.
  #6
Old July 28th, 2008, 11:39 PM
xxxflhrci xxxflhrci is offline
I just mounted a Humminbird 610 in mine last week and tested it today on the water. It worked great. I first tried filling the bilge with water and testing the transducer for the best locations. It worked o.k., but not great. I picked a spot and epoxied it down with the supplied glue. It worked fantastic with the epoxy.
Reply
Search this Thread:
Advanced Search
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Similar Threads
transducer mounting: is inside the hull mounting a bad idea? 3car Electrics, Electronics and Trolling Motors 4 September 27th, 2007 09:12 PM
Still shopping - More info requested GiMLit Boat Topics and Questions (not engine topics) 4 August 9th, 2007 11:09 PM
Prop info requested CaptainTerry Johnson & Evinrude Outboards 4 April 5th, 2007 01:48 PM
'88 liberator info. requested mr. larry Four Winns Boats 1 July 17th, 2006 09:12 PM
Info requested for a johnson 50 johnson50 Johnson & Evinrude Outboards 1 August 19th, 2004 05:27 AM
iboats Forum Directory
Outboard Motor Topics
Mercury Outboards
Johnson Outboards
Evinrude Outboards
Force Outboards
Yamaha Outboards
Mariner Outboards
Suzuki Outboards
Honda Outboards
Chrysler Outboards
Tohatsu Outboards
Nissan Outboards
Outboard Motors: non-repair
Vintage Outboards
I/O and Inboard Topics
MerCruiser
OMC I/O, Inboard
Volvo Penta
Propeller Help
Boat Propellers
Boat Repair and Products
Boat Building and Repair
Fiberglass Boat Repair
Marine Electronics
Boat Trailers and Towing
Boat Names
Boat Parts
Boating Activities Talk
Boating Topics and Questions
Boating Blunders
Boat Shows
Wakeboarding
Water Skiing
Fishing Discussions
Freshwater Fishing
Saltwater Fishing
Boat Type Topics
Aluminum Boats
Bass Boats
Bowrider Boats
Center Console Boats
Cruiser Boats
Cuddy Cabin Boats
Deckboats
Fishing Boats
Fish and Ski Boats
Houseboats
Jet Boats
Jon Boats
Pontoon Boats
Powerboats
PWC Forum
Ski Boats
New Boats
Used Boats
Boat Manufacturers
Boats 250+ Manufacturers
Bayliner Boats
Sea Ray Boats
Zodiac Boats
Outboards
Power Heads
Lower Units
Propellers
